Read an external bitmap file
atankersleyatankersley Member Posts: 32
edited 2008-01-31 in Navision Attain
I have item pictures for 20,000 items. What I want to do is store the pics in an external file and read them into the item card on the fly for display. I thought I could use an instream, but I am hung up on how to read the bmp file with the instream I created from the Item.Picture.CREATEINSTREAM(). I would be very thankful for any insite on this.
tank
  • SavatageSavatage Member Posts: 7,142
    http://www.mibuso.com/forum/viewtopic.php?t=16184
    they key here is to have the picture name the same as the item no.
    On the Item Picture Form
    OnAfterGetRecord()
    Code:
    SETRANGE("No.");
    IF EXISTS ('P:\BMP\'+"No."+'.BMP')
    THEN
    Picture.IMPORT('P:\BMP\'+"No."+'.BMP',FALSE);
    CALCFIELDS(Picture);
    That's it - now your pic will show.
    note p:\bmp\ is the drice & directory where we store our pictures. change it to fit your drive & directory names
    as Kriki or Alex stated in another post - if you are using ver5 you can link the pic just as you link different external docs.
    note adding CLEAR(Picture);
    OnModify of the item table. insures the pic won't be saved while viewing the pic and someone makes a change on that item.
    Note: If you modified your item card to show the picture in a picture box then add the code to the item card not the item picture form
    last thought: assuming you're never imported pictures then go ahead and use the above code. If you have already imported pictures and want to clear them from Item.Picture blob without having to go one by one.
    create a report based on the item table.
    OnAfterGetRecord()
    IF Item.Picture.HASVALUE
     THEN
      CLEAR(Item.Picture);
       Item.MODIFY;
    did i miss anything? :-k
    OOOH!
    If you don't have access to the code on the forms & tables.
    You can Create a Report based on the item table.
    View the sections and put 1 big picture box with sourexp as Picture
    add the code
    OnAfterGetRecord()
    THEN
    Now on the item card add a command button
    PushAction:RunObject
    The object will be this report.
    Unfortunately at this point you will need to transfer the parameter of which item your on tot he report, which will require some more coding but if you ok with manually entering the No - this way will work too
    Not as pretty & nice thou.
  • atankersleyatankersley Member Posts: 32
    Thanks alot Savatage. Your code worked perfectly.
    tank
