Hi everyone,
Based on the MSDN-article "
Talking with Navision: Exposing .NET Components to Navision" I have developed a COM Automatation Server (AT). This AT needs to be instantiated through a codeunit:
CREATE (ATServer);
ATServer.test('Hello World');
Once the AT is instantiated, it will run on the "background" and listen for incoming events.
Note: When I run the codeunit in a NAV client, the AT is working properly. If I exit the NAV client or switch the company, the AT stop running.
My questions:
1. This codeunit should now being executed in 4 companies with a NAS (the NAS has only to start (run) the codeunit, that's all).
Is there a possibility to run this codeunit with the same NAS (start the codeunit in each company) or do we have to buy 3 additional NAS license ?
2. As far as I know, the NAS connect to the NAV DB under a specified NAV user account. Do we have to license this user separately or is this user included in a NAS license ?
3. If we need a separate NAV user license for the NAS (see question 2), is it possible to use an existing user for the NAS (the user works on the NAV client on the same time) ?
I hope you understand me, because my english couldn't be very good
Thanks a lot!!
http://www.mibuso.com/dlinfo.asp?FileID=924
Navision comes free with 1 NAS user, you need to purchase 1 additional license .
Depends on your licensing. Are you using Named users licensing or generic user licensing?
I don't have experience with Named user, because in US no company buys it, but with generic regular licensing, it's the number of users that are connected.
As for as your .NET automation concerned, I would instantiate one and in your events pass a parameter for the company it should run it and NAS can start the second instance based on link above and run it for that company.
That means, that we have only to buy an additional NAS license (~ $2000.-) and not NAS license + NAV user license (~ $2000.- + $3000.-) ?
For our 10 users we have 10 generic user licenses.
So the NAS 1 will always be connected to company A. If there is an event for company B, NAS 1 starts NAS 2 and run the codeunit (which instantiate the AT at company . After AT has finished all its operations, the codeunit will disconnect the NAS 2 (so NAS 2 is ready for the next event).
Freelance Developer
Yes you need to just purchase one additional NAS license.
Yep.
There are also supported products that can do this. Here is a demo movie of the iFacto NAS Scheduler. This product is tested and registered at Microsoft.
2.
A NAS license is not the same als a user session. As Ara3n said, one NAS license is for free. The user that you link with the NAS does not need an extra user session. For both NAS Schedulers, you need an extra NAS sesion though.
3.
I never heard of named user licenses (probably never used in Belgium). User licenses usually are concurrent licenses.
Eric Wauters
MVP - Microsoft Dynamics NAV
My blog
I will make some tests with the "NAS Job Queue" next week . If the performance is ok, it would be a good & easy solution (keep it quiet and simple)
Freelance Developer
No prob
Eric Wauters
My blog
