hi all,
while posting opening qty of items i have not posted the coost.
after 3 months we have posted it through revaluation journal.
i want to adjust the cost for getting item costing.
when i run "Adj. Cost item Entries" batch job, it keep on running
since more than 30 hours.i have run it three times.every time it is taking
so much time.
Pls suggest how I can do it.
client is in critical position as he is unable to get the costing.
Nrapendra Singh
(Sr. Tech. Consultant)
Dataman Computer Systems (P) Ltd.
web :www.datamannet.com
mail :nrapendra@datamannet.com
Freelance Dynamics AX
Blog : http://axnmaia.wordpress.com/
as he is running navision.
I dont know how the people are working and how they are
able to run their business in efficient manner using navision.
I think either microsoft should scrap this product or correct these
blody bugs.
Check in partnersource for your current version and apply the correct hotfix. It's simple to correct this.
That way you can run it several items at a time.
http://www.mibuso.com/forum/viewtopic.php?t=18943&highlight=
Now I'm confused. Did your adj. cost ever finished after 30 hours?
Wow that's harsh, "Scrap this project" I never thought of Nav as being a little MS sideproject.
It run great & it's made our business lean & mean. There are hot fixes for bugs such as the one you are experiencing. What version are you using? It's been very clear to us for the years we've been using Nav that running Adjust Cost Batch job on a regular basis is the way to go.
http://www.BiloBeauty.com
http://www.autismspeaks.org
As one of our clients likes to say "Sometimes you need to fix the loose nut behind the keyboard"
What version are you using? In 5.0, they introduced Inventory Periods so you can run adjust cost for a particular period.
I really find myself too helpless.
