Have a NAV 4.0 SQL customer who did not back up their SQL Transaction Log for a long time. Now it is very big and when they try to back it up so all completed transactions are removed, there is not enough disk space to do so. Any ideas how to recolve that without taking any risks? Seems like it got very big very fast because they by mistake activated NAV Change Log for all fields.
Create a new db and restore the navision backup .fbk.
And you should be set with small transaction log, and a small db.
Send me a PM if you need help setting that up.
RIS Plus, LLC
MVP - Business Apps
Yes, just keep providing the extra backup tapes (and reuse them while backup up).
