How to know which decimal sign Navision uses
edited 2007-07-05 in NAV Tips & Tricks
How can you know which decimal sign Navision uses?
GetDecimalSign() : Text[1]
// GetDecimalSign
// Returns the decimal sign currently in use by Navision
// PARAMETERS:
//   RETURN-VALUE : Decimal Sign currently in use (',' or '.')
EXIT(COPYSTR(FORMAT(1.5),2,1));
