I want to create a Navision Custome Control (OCX or DLL) -> for example one dll which create a "Hello World" massagebox after starting from navision.
I use Visual Studio 2005 .NET. C# is the favorieted language.
Can someone give me a Code example or guide for the dll?
Check out our new
NAVonline HelpDesk0
Namespace Something
<ClassInterface(ClassInterfaceType.AutoDual)> _
Public Class Starter
Public Sub SayHello()
messagebox.show('Hello world')
End Sub
End Class
End Namespace
in prpreties of solution chose "output type" - class library
in configuration prop check the "registrer for COM interop"
Now you can use method of your dll in navision
can you give me a hind?
I find it!
I can't import the dll in Navision Custom Controls. Error: OLE Control can't register
..psst. you can't register dotNet components in NAV Custom Controls, use regasm instead..
Rvduuren
http://valpi.pt/web/valpi.nsf/a9d3838b9 ... enDocument
http://www.BiloBeauty.com
http://www.autismspeaks.org
The other Samples i will test tomorrow - thank you all
Some sample code could be useful if you have done so in the past.
Tim Larson
