Dear All,
I am currently creating a report, but I am not understand when I put one item in the purchase
line, then it's ok, the page is only one page when I preview the purchase order report. but after I put 2 items in the purchase line, the purchase order report page become 2 pages.
The coding in the C/AL :
dataitem : integer
Integer - OnAfterGetRecord()
IF "Last Purchase line" THEN
BEGIN
CurrReport.BREAK;
END
ELSE IF "Last Purchase line" = FALSE THEN
BEGIN
"Dummy Line Counter" := "Dummy Line Counter" + 1;
IF "Dummy Line Counter" > 35 THEN
CurrReport.SKIP;
dataitem : purchase:
Purchase Line - OnAfterGetRecord()
"Purchase line counter" := "Purchase line counter" + 1;
IF (Type <> 0) AND ("No." <> '') THEN
Sequence := Sequence + 1;
PlineRec.COPY("Purchase Line");
IF PlineRec.NEXT <> 0 THEN
"Last Purchase line" := TRUE
ELSE
"Last Purchase line" := FALSE;
IF "Purchase line counter" >35 THEN
CurrReport.NEWPAGE;
disc := disc + "Line Discount Amount";
Could you provide me a hint to solve this problem, because if I set purchase line counter > 5, then the table in the report page doesn't fit the whole page according to our need. There is only 50% fit the page. The section contains table, no., item no., description, qty, unit of measure, unit cost and total cost. I apreciate your answer. tku
Rgds,
Andreas
And for what purpose is the integer-dataitem?
Just disregard my first question and I renew now. I am willing to have a purchase order and sales order report and set dataitem as follows:
DataItem Name
Sales Header <Sales Header>
Sales Line <Sales Line>
Integer <rowline>
C/Al for dataitem:
sales header:
Sales Header - OnAfterGetRecord()
SubTotal := 0;
Sequence := 0;
TotalGrossAmount :=0;
TotalAll :=0;
Tax :=0;
counter := 0;
rowline := 0;
Discount := 0;
GrossAmount := 0;
Sales Line:
Sales Line - OnAfterGetRecord()
counter := counter + 1;
IF counter > 43 THEN BEGIN
counter := 0;
CurrReport.NEWPAGE;
Integer (rowline):
rowline - OnAfterGetRecord()
rowline := 43 - counter;
IF Number > rowline THEN
CurrReport.BREAK;
The section parts consists of:
1. Sales Line, Header
2. Sales Line, body
3. Integer, Body
4. Sales line, Footer
C/AL for section 1:
Sales Line, Header (1) - OnPreSection()
SubTotal := 0;
TotalGrossAmount := 0;
Discount := 0;
TotalAll := 0;
C/AL for section 2:
Sales Line, Body (2) - OnPostSection()
SubTotal := SubTotal + Amount;
GrossAmount := "Line Amount";
TotalGrossAmount := TotalGrossAmount + GrossAmount;
Discount := Discount + "Inv. Discount Amount";
TotalAll := TotalGrossAmount - Discount;
The problems are how to make my report generated by the system consists of 39 items. The second problem is how to join the horizontal shape with vertical shape if the field PlaceInBottom of sales line footer section properties I select yes. The vertical shape are placed in the sales line body and integer sections, meanwhile the horizontal shape are placed in the sales line footer section. Could you tell me the solution then..? tku for your answer beforehand.
Rgds,
Andreas
actually exists in the first page.
Rather then explaning your code please tell us as kriki said what exactly is your requirement so that we can help you more precisely
My problem is that the report I created for sales or purchase order can not contains 39 items to sell (sequence qty of items must be as same as the items exists in the sales order line of sales order from no. 1 to 39).
I have created the coding, section etc as mentioned above. I don't want the report is two pages.
If the report one pages it should contains 39 items, but it is not. You know that if it is sales order or purchase order oc course the report contains no., item no., description, qty, unit of measure, unit price/cost, total amount.
and in the footer of course there is grand total field so sum all 39 items.
I apreciate yout answer so much. Tku.
Rgds,
And if you have 100 items in a salesorder? I mean:sooner or later you will have so many items, you will have to use 2 or more pages.
-To put more records on the pages, you can make the lines-section smaller (using a smaller font, so the textbox can be smaller, so the section can be smaller), you can make the header and footer section smaller. But still... sooner or later you will need more pages...
Rgds,
Andreas
It is not necessary that you count the lines to decide when to do a Newpage. Navision takes care of that.
BTW : do you have multiple sections with property PlaceInBottom=Yes. And in the OnPreSection you decide to show or not to show them? In this case, Navision reserves space for printing ALL of them. If this is the case, you should use only 1 of those section and then clear or not clear some fields on them.
What I do is in the SalesHeader - OnAfterGetRecord trigger, writing code to count the no. of lines in the order, and to insert new lines (with Type = '', Description = ' ') until there are 39 (or a multiple of 39) lines in the order.
In the SalesLine - OnPostDataItem trigger, you write your code to delete the inserted lines.
This way, you don't have to use a Integer dataitem to count the no. of lines.
Tku for your reply. The problem I have in creating report can be viewed from website.
I will describe the pictures:
1.PO-Overall-1items.JPG --> this picture seems ok but there is a problem inside it when it contains 3items.
http://www.geocities.com/andreas2975/PO ... 1items.JPG
This PO contains 3 items if viewed thoroughly in page 1
http://www.geocities.com/andreas2975/PO ... -page1.JPG
This PO is continuation of picture PO-3items-overall-page1.JPG i.e. its page 2.
http://www.geocities.com/andreas2975/PO ... -page2.JPG
This PO placeinbottom field of purchase line footer section properties is selected to yes. The result of setting is this picture and it looks like PO-3items-overall-page1.JPG
This picture is continuation of PO-3items-placeinbottom-yes-page1.JPG and it seems that there are missing shapes (vertical shapestyle) that connecting top and bottom and I thought it can be like PO-Overall-1items.JPG and contains 3 - 35 items as you have said.
The codings and section picturescan be seen in the pictures:
http://www.geocities.com/andreas2975/pu ... coding.JPG
http://www.geocities.com/andreas2975/integer-coding.JPG
http://www.geocities.com/andreas2975/PO ... n-view.JPG
To more clearly just download the file from this website:
http://www.geocities.com/andreas2975/int-report1.zip
I just want to maintain the report I designed and overlook the std report available in navision. Indeed it is a base of study but can't be treated
as a guide.
I I am very hoping by seeing the website, the problem can be seen clearly
and I can have the answer. I really appreciate your answer. tku.
Rgds,
Andreas
P.S.
If I can pay for the report or the answer, maybe I can send the money
for your answer, but I hope not too expensive.
And you can use the normal Purchase Line Footer and Transfooter sections to close your rectangle/frame properly.
Tku very much for your quick reply. I will try this nite.
And 2morrow will send the result. I didn't mean to disregard your answer.
Rgds,
Andreas
