This is Ajay. When I am running the codeunit (5500 - Production Schedule Management) Production Schedule in Navision 4.0 , It raises the following error
The table "Subtitle" uses the non existent filter "<AUTOMATICALLY>".
The filter entry ist correct to "<always>".
Can anybody give me the solution.
Ajay
Ajay
The thing is I don't have Axapta in my system. I have both the versions
Navision 3.7 and Navision 4.0 in my pc.
Can u please tell me the solution.
Ajay
Try to search for another copy of the vcgantt.ocx on your pc and try to unregister it...
=D>
Its working
Ajay
I looked in the ProdSched variable declaration and it says Unknown Automation Server.Unknown Class
So where can I find this vcgantt.ocx? Does It appear in the list with another name because seems like I don't have it?
thanks
NETRONIC VARCHART XGantt
C:\Program Files\Microsoft Business Solutions-Navision\Client400SP3\vcgantt.ocx
The problem is i dont have NETRONIC VARCHART XGantt in Navision's automation list.
I did a search for the vcgantt.ocx and not found either, but I managed to get this file from an Axapta distribution, registered it and I got the same message when I try to run the CU 5500 in Navision.
I have NAV4 SP2. Think we need the SP 3?
2) The ocx is on the NAV install CD, but you need to change the install options (custom install) if you want to have it installed. I am not sure, if it is part of the standard installation.
Ok I will unregister the ocx from axapta.
I cannot re-install navision, I must make this CU work on several clients with NAV4 SP2 so where can I find the ocx and how to register it?
All I need is the vcgantt.ocx file?
I copied the vcgantt.ocx to client folder of the running Navision and I get the message:
Load library("vcgantt.ocx") failed. The required modul was not found.
Do I need to re-install Navision? because this is not the desired solution for me..it will take a lot of time
yhanks
(this is my 4000st post... \:D/ )
have you solved your problems?
Could you please take a look to this post regarding similar problems on Gant Server NAV 5.00. I have no errors but not the correct language.
http://www.mibuso.com/forum/viewtopic.p ... highlight=
Thank you very much
Andy
I think to have solved also my problem copy all 7 files that you wrote from version Italian to version Swiss.
Thank you very very much
- vcgant.ocx
- NavisionGanttServer.exe"
- "NavisionGanttServer.exe.manifest"
- "vcgmbs.dll"
- "vcpane32u.dll"
- "vcwin32u.dll"
- "VXCSV32u.dll"
from two different localizations.
These files are used also for others things or only for Gant Server?
Thank you
Andy
