It is currently Thu Sep 02, 2010 10:08 pm
Post new topic Reply to topic  [ 3 posts ]
 Post subject: NAV 4.0, Localized Excel and property Formula
PostPosted: Tue Aug 07, 2007 9:40 am
Country: Czech Republic (cz)
Because in NAV is a small bug which don't allow write to property Formula of Cell US expression then it's big problem write transparent international application with localized Excel.
I found a small trick how to get subfolders for any folder though NAV don't know FOR EACH - Windows Script Host Object Model Folders and Files.
There is result:
variables:
Name DataType Subtype Length
loScript Automation 'Microsoft Script Control 1.0'.ScriptControl
lcCode Text 1024
loData Automation 'Microsoft Scripting Runtime'.Dictionary
lcPom Text 1024
lii Integer
Code: Select all
CREATE(loData);
CREATE(loScript);
lcCode :='loCell.Formula=loList.Item(1);';
lii:=1;
// for each cell
XlCell:=XlWrkSht.Range(xlColID + xlRowID);
loScript.Language := 'JScript';
// Add objects
loScript.AddObject('loCell', XlCell); // excel cell
loScript.AddObject('loList', loData); // dictionary object
lcPom:=GetFormula(); // Formula definition
loData.Add(lii,lcPom); // Add formula to dictionary object
loScript.ExecuteStatement(lcCode); // Execute javascript
loData.RemoveAll(); // remove item from dictionary
loScript.Reset(); // reset Script object for next using
MartinaJ
 Profile
 Post subject: Hi Martina
PostPosted: Wed Aug 08, 2007 11:52 am
Country: India (in)
Nice meeting you.
I have tried with the example you provided. But I did't able to compile the code because of 'GetFormula()' Function it is not defined from where this function has to be called.
Please, Provide the Solution for this.
kiran.
_________________
 Profile
 Post subject: kirankumar
PostPosted: Fri Aug 10, 2007 7:38 am
I'm sorry. GetFormula is trigger from table 370 (Excel Buffer)
Code: Select all
CREATE(loData);
CREATE(loScript);
lii:=1;
// for each cell
XlCell:=XlWrkSht.Range('C5');
// Add objects
loData.Add(lii,'=SUM(C1:C4)'); // Add formula to dictionary object
 Profile
Users browsing this forum: No registered users and 2 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
