Microsoft Dynamics Nav Business Web Services not found
akshay_Maliakshay_Mali Member Posts: 4
edited 2015-08-05 in NAV Three Tier
I have installed Microsoft Dynamics Nav 2013 (Customized). Though server is successfully installed windows services is not showing "Microsoft Dynamics Nav Business Web Services" . ](*,) Can anyone guide me how to install it?? Or it needs to activate seperately. ??
    defiant701defiant701 Member Posts: 79
    https://community.dynamics.com/nav/f/34/t/168235
    There are not dedicated services in NAV 2013.
    Debuggers don't remove bugs, they only show them in slow-motion
    LinkedIn
    XING
    Thanks for your reply .
    But when I try to Enable SSL and try to save the configuration using Microsoft Dynamics NAV Administration , I get this error message:
    Error : -
    "Changing the value for that enables SSL for OData- or SOAP- services are not supported. See '' for more details." http://msdn.microsoft.com/en-us/library/ee414212.aspx for more details.
    That link goes to an article on NAV 2009 which doesn't really explain why I can't enable SSL. Also it shows that "Microsoft Dynamics Nav Business Web Services" exist in services.
    Can anyone tell me why I am getting this error?
    you should check your installation if there are still some old 2009 files. How to enable SSL for 2013 can be found here https://msdn.microsoft.com/en-us/library/ee414240(v=nav.70).aspx
    But you should skip 2013 and upgrade to 2013 R2 where the web services run much more stable.
    KR
    Dirk
    LinkedIn
    XING
    Thanx..
    But I have uninstalled All previous version and then installed Nav 13. And yes I am thinking to change version but not 2013 R2. Trying for Nav 2015
    yes 2015/2016 is also much better. Can you post a screenshot where you get this message from?
    KR
    Dirk
    LinkedIn
    XING
