Readmultiple fail in Purchase Order Page Web Service
amphysvenaamphysvena Member Posts: 113
edited 2014-10-02 in NAV Three Tier
I published Page 50 - Purchase Order as Web Service in NAV 2013 R2.
After that, I consume that webservice in my .NET 2012 winform. My code is like this :
wsPO.PO clsPO = new wsPO.PO();
wsPO.PO_Service svcPO = new wsPO.PO_Service();
svcPO.UseDefaultCredentials = true;
List<wsPO.PO_Filter> lstFilter = new List<wsPO.PO_Filter>();
wsPO.PO_Filter filter = new wsPO.PO_Filter();
filter.Field = wsPO.PO_Fields.No;
filter.Criteria = "TEST0013";
lstFilter.Add(filter);
wsPO.PO[] arrPO = svcPO.ReadMultiple(lstFilter.ToArray(), "", 0);
foreach (wsPO.PO p in arrPO)
MessageBox.Show(p.Buy_from_Vendor_Name);
The problem is, the ReadMultiple doen't work, and I'm sure the document no. is exist. The Read method is also fail, because the parameter in Read method only shows 1 parameter (Document_No string) and it always return Null.
Do i miss something? The code above is work on 1 key table, like Customer, Item Ledger Entry, Item.
  • amphysvenaamphysvena Member Posts: 113
    Never mind, finally fix the problem
  • krikikriki Member, Moderator Posts: 9,094
    You could post what you did to fix. It might help others.
    Somehow my webservice are broken. I mean they shows the wrong key, and update the web reference does not help. So i just delete the web service and add it again.
