Send To Excel problem after Migration from 2013 to 2013 R2
Igor_PchelnikovIgor_Pchelnikov Member Posts: 25
edited 2014-09-11 in NAV Three Tier
Hello everyone,
after migration to 2013 R2 SendToExcel produces blank file and Addin is not visible in Excel (2010).
But when Excel is started manually - addin is available.
Previously there was 2013 version (uninstalled), but seems not all files/registry settings were removed correctly.
Anybody can share info how to resolve this problem or what to change in registry?
Thanks!
  • aniishaniish Member Posts: 27
    go on below location
    ‘C:\Program Files (x86)\Microsoft Dynamics NAV\71\RoleTailored Client’,
    and try to run ‘Microsoft.Dynamics.Nav.ExcelAddin’ .
    Might be it will resolve your problem.
    Thanks, Gaurav
  • nhsejthnhsejth Member, Microsoft Employee Posts: 34
    If you can modify the registry, it easy to remove all traces of the Excel addin.
    Remove the following keys from your system (export them first to have a backup in case you would like to restore the original functionalty))
    HKCU:\Software\Microsoft\Office\Excel\Addins\Microsoft.Dynamics.NAV.ExcelAddIn
    HKLM:\Software\Microsoft\Office\Excel\Addins\Microsoft.Dynamics.NAV.ExcelAddIn
    HKLM:\Software\Wow6432Node\Microsoft\Office\Excel\Addins\Microsoft.Dynamics.NAV.ExcelAddIn
    Remember to be carefull when you modify the registry.
    _________________
    Niels-Henrik Sejthen
    Senior Software Developer
    The information in this post is provided "AS IS" with no warranties, and confers no rights. This post does not represent the thoughts, intentions, plans or strategies of my employer. It is solely my opinion.
