Problems with RTC Report
roadrunner64roadrunner64 Member Posts: 3
edited 2012-03-20 in NAV Three Tier
I have createt a Add-In wich use RTF TextBox. I can also save the Text as RTF formatet Text to the NAV-Database into BLOB file.
But i can't finde a solution to Print the RTF File correct in the NAV-Report. I got always the rtf-formatet text.
Have anyone a god idea?
Thank's
    Troubles_In_ParadiseTroubles_In_Paradise Member Posts: 588
    Thank's
    I found your request interesting so I made a little search and I found a link abount RTF in reporting services (since Nav doesn't give all Reporting Services potentiality, I hope that's supported).
    http://social.msdn.microsoft.com/Forums ... d5c9e8286/
    In this link is suggested "to convert" the RTF into an image and then print the image in report.
    As I told you before I didn't tested it and I admit that I don't know how useful could be for you... let us know.
    ~Rik~
    It works as expected... More or Less...
