I am working on Nav 5.0 sp1.
In purchase order , In direct unit cost field I have to enter 202.3659.
But when I try to enter system is throwing some message
That is
The field can have a maximum of 2 decimal places.
For this I am giving some information about my setups ;
Currency code = Blank
G/L setup :
Amount decimal Places = 2: 4
Unit – Amount decimal places = 2: 4
Currency card setup :
Amount decimal places : 2: 5
Unit amount decimal places : 2: 5
Why the system is throwing this error.
Where I need to change the setup
Even I try to run the debugger to find out the problem.
Debugger is not working for this error only.
So I throw this query to forum to know the answer from experts
hansika
I changed the decimal field properties for that field.
Still it is not ready to accept that values as 20.4568 in direct unit cost field.
My question is how to change ?
Why debugger is not working ?
Check the various Rounding Precision field - I suspect that you have some set as 0.01
Dynamics Nav Add-ons
http://www.simplydynamics.ie/Addons.html
